St Aidburns
St Aidburns
We went for a walk today and I took the XT-3 with me . I had decided to keep up the experiment and pushed up the ISO to 1250.
I know it's not an earth shattering figure but it was more than I would normally use.
Here are the three shots I took they are only for research .See what you think ,It was quite a bright day. 8-)
ASCF0753 (1).jpg (851.11 KiB) Viewed 3137 times
ASCF0751 (1).jpg (1.05 MiB) Viewed 3137 times
Re: St Aidburns
Did you use De-Noise on these.
There is a little bit of noise but not much, the Dragonfly handles it well. 8-) 8-)
Re: St Aidburns
Yeah I did use De-Noise but only on med setting but I can't tell the
difference between Med and High sometimes.
The Big problem is and it's same with the Canon I could go out tomorrow
and 800 Iso will be noisy :roll: :roll: :roll:
